My new Snorkel Scoop install instuctions for 73+ Dusters...
myasylum
Las Vegas, NV
O.k. I did some reading on this before I started. I did see some instructions for 72 and under Darts. I was using that as an example but even with that it didn't really go into detail of where to start with drilling the 8 holes!
So I just dug in, and got down and dirty, I thought I'd post this for others having the same questions in the future. If for some reason this seems incorrect, I'm sorry in advance, but this is what worked for me, and believe me, it took awhile. I'm no expert body man.
First I made a template. I just took a large piece of cardboard, and set the scoop on top of the cardboard. I pushed down a bit on the scoop itself so it left indentations on the cardboard itself. Then I traced around the scoop and cut it out.
I then laid the cardboard on the hood...
I then found all measurements, from the holes for the studs out to the edge of the hood. This might seem obvious, but this is how I measured all
sides with measuring tape.
Then this is the measurements I found.
3 1/4 from the top of the hood to the top of the cardboard (which was cut to the outline of the scoop, this also follows the stock positioning for Darts as well)
6 7/8" from the two side studs (holes) to the end of the hood.
20 3/8" to each side from the same studs (holes) to the side of the hood.
18" to each side from the center studs (holes) to the sides of the hood.
18" to each side from the front two studs (holes) to sides of the hood.
Now for the front stud I ran out of cardboard, but I figured out that the studs are 22" apart, so the obviously the center is a 11" then with a straight edge, going across the studs, and measuring up to the top stud, it is 2". That is where I placed my final front center stud. I also used tape to hold the cardboard in place while using marker to mark my spot. (Remember as Indiana Jones says, "X never marks the spot" :)
(As a word of advice before you start drilling, be careful. If your drill slips it will wonder off, you can easily loose your drilling point and and sucks! Not to mention scratch the paint on your freshly painted car. Then you'll end up cursing and wanting to kill people. Don't ask me how I know this! :angryfir:)
Now, once holes are drilled we have another issues. Because we had to drill through the cross members of the hood, the studs don't fit through the cross members on the INSIDE of the hood. So You have to buy one of these thingamabobdohickys... (Kind of looks like Satan)
This will enlarge your hole (I said "hole") so you can get at the studs, and fit a socket in there to tighten the nuts. I used a 1 1/8" 29mm thingamabobdohicky.
I hope this looks straight to you, because it does me. Not only that, but I think I'm sober.
Just a couple things to mention, I did go to the local hardware store and buy rubber O-Rings for the studs, just for rust reasons on the hood, tiring to keep the water out. Also I used some primer, to cover any bare metal so it wouldn't rust. I don't know if this is something you need to do, but it seemed like a good idea too me.
Also make sure your drill is fully charged, or use a corded power drill, especially for the extra holes inside the hood. It's a bummer when you start a project and realizes your drill is only half charged!
O.k. I'm done. I hope this is useful for somebody?
Thanks.
This is very use full to me as I am going to be doing the exact thing very soon. Possibly tomorrow. Thanks.
Great! I'm glad I could help someone. I sure wish I had this before I started, it would have saved me a lot of time. You might want to double check just to make sure, I'd hate to be wrong, and have anyone not be happy. Even if it's not perfect though, it's gotta be pretty darn close. While doing this it often made me question how accurate the stock measurements are on these hoods are anyway?? I'm sure there was some tolerance allowed.
Let me know how this works for yea.
Looking at the forums I've realized maybe this would be best suited in the Body/Interior/Trim forum. If someone wants to move this, I understand.
Thanks!
Looks great and you dun a good job :cheers:Thank you for sharing.
Yes, Pine Tree Mopar, that is the thread I started to use for guidance
http://www.forabodiesonly.com/mopar/showthread.php?p=95114#post95114.
That is how I figured out that the stock distance from the scoop to the end of the hood was 3 1/4"... It must be dead nuts for the 73+ years as well, because if you look at the holes under the hood, they are identical to the 72- Darts.
The rest of the info I pretty much figured out on my own. There was no discussion on that thread for stud placement.
Thanks for your thanks! :)
Looks great! I have a scoop as well, but can't bring myself to cut up the hood and install it.
Your color combination (Black and Y6 Gold) is absolutely the best one for a 73+ duster, but then I may be partial...
Soooo..... I have a '71 Demon hood with a huge hole in it for a tunnel ram. Any guess as to if this scoop will fit over the hole and save the hood?
