superdart
Shade Tree Tinker Gnome.....
Very disturbing......
At idle, still warming up, my engine shows 60-70 psi oil pressure.
As I drive it on the highway (20-30 mile run) the oil pressure slowly drops down to about 40psi.
Yesterday was 100 degrees here, and after a 5 mile drive around the block, I got back to the house and at idle I was only showing 25 psi!
I shut it off and left it in the drive because I had other things I needed to get done. What REALLY concerns me is the strange groaning noise I got when I started it to pull it in the garage. I had heard it before when moving, and assumed it was a suspension noise...but the car was still in park. It moaned a bit, I revved it slightly (1500 rpms)and it went away, I let off the gas and it came back. Just a quick moan, then it stops. Then it will do it again.
Low oil pressure, odd noises at low rpms...am I losing my main bearings? The motor only has maybe 4k miles on it, and was built by a local guy with a very good reputation when it came to SB Mopars. He has since passed on, so the specs are the only thing I have on the engine. I played with the rockers/pushrods but otherwise have never been inside the motor.
Pertinent Specs:
.030 over 360
9:1 CR
455/475 Herberts E3N cam
HV oil pump
.010/.010 ground crank (maybe the culprit?)
Amsoil 10W40 Zinc oil
I seek the wisdom of others....
Pertinent Specs:
.030 over 360
9:1 CR
HV oil pump
