Mystery to me wiring harness
dodgemahal
Illinois
I'm restoring a 1973 4 door Dart Custom. There is a 2-wire harness with a connector at the end that's under the carpet and just to the right and adjacent to the transmission hump. What does this connect to?
I'll get some pictures tomorrow. Im pretty sure there's no connector on the seat. There's wiring going to the seatbelts that are attached along the door openings. They trigger the dash light.
Yellow ring is where it's located. The other photo is with the carpet pulled back.
As mentioned, that’s seat belt warning related, red and grey wires for the right seat weight sensor switch. The switch may been removed from the seat cushion springs if not able to locate the seat wires.
