Name that trim .......
65BCODA
EUSTIS,FL
I found these trim pieces in my stack and do not believe they go to an early cuda.
There are 6 pieces total all the same profile, (2) are 24 1/2" long and (4) are 35 1/2" long.
All pieces are 3/8' wide and the rear have integrated clips similar to the felt window whiskers. All are in great shape.
I have a use for two of the longer ones as possible accent strips on my home brew door panels …… but if they can be identified as something someone needs or ??. I'll forgo bastardizing them on the door panels.
A couple look like the trim that goes on the doors right up by the window.
I also like the idea of using them as trim on the door panels
That’s what I was thinking some sort of window trim but not an early A
Those ARE door panel trim. The giveaway is the bend tabs on the back side...I've had some panels that used those, but I'm not sure on the application except that they fit my '67 Barracuda doors, but were not originally from a Barracuda.
good luck I have 2 68 cudas . they have gilles. danm hi dollar but 71 cuda was 2 b only one to have. I love it.
