Napa 103228X
ronw
cashtown,Pa.
Working on 68 dart 340 GTS. When installed the Napa 103228X the chain had at least a 1/4" play on both sides. I'm sure this Is not right. The motor is a 340 block dated 68. I need the correct timing chain. Can anyone help me with the right timing chain number?
Has the main saddles been align bored? If so u will need to get a shorter chain from somewhere, they do make them or u could put in a tc tensioner from a mid 90s 3.9 litre Dakota. Kim
Make a phone call... anybody that sells engine parts can get you what you need.
