22785auto
390DART
Narrowed 8 3/4 rearend.
48 inch flange to flange. 1 1/2 inch diameter, 35 spline axles, 4 1/2 x 5 bolt pattern. 489 case with a spool and 5:13 Richmond gear. Wildwood 11 1/2 inch disk brake rotors with 4 piston calipers. Existing spring perches will need to be removed, and new perches welded on. I will add pictures. Good for an A body mini tub. Used in good shape. Local pick up only. Romeoville IL. I can deliver to Chicagoland Mopar Connection, Mopar Madness show on June 1 in Downers Grove IL. $1500.00 John PM for more info
