need a pic of a 69 340 mounted distributor and oil sending unit
What in particular are you looking for???
orientation of the vacuum advance, coil mount and oil sending unit
Give me a few minutes to go to the back garage and look...
Here's some music to listen to while you are on hold....
69 340:
71 318 (the coil bracket mounting is the same...
Is that a plywood firewall ? Weight savings trick ? Lol
No, the wall in my garage in back... We used wood panel instead of dry wall...
Is that the correct orientation of the coil, pointing to the drivers side ?69 340:
Looks like that 340 needs a new home?! I can give it a warm home with plenty of love and affection. I'll even let you take one of my kids in trade if you would like.
He's hiding one of theseIs that a plywood firewall ? Weight savings trick ? Lol
