[SOLD] need a 70-72 a body parts car
rbkt65
jerseyville, illinois.
helping cousin trying to put together a dart. needs a lot of stuff. need a 70-72, prefer a dart he says. have a lot of parts to trade. i am throwing in a lot of my stuff to try and help out. we have a std 440 block that needs hot tanked and bored. a std std steel crank, a set of 452 heads, a lot of the tin parts and bolts. the pistons are sealed power L2355f in .040 with resized rods and arp bolts. 1 piston is new without rings. engine was on dyno when it dropped a valve on decel. it broke block and 1 piston and rod. hence 1 new piston and newly resized rod. camshaft and double roller tc and gears. camshaft is engle ep-18hyd. .458 lift and 260 adv duration .there is also a set of 915 casting sb heads w/2.02 valves that may/may not need some work. they have been sitting on shelf for about 7 years in his basement. we have not found a water pump housing as yet. if we do that will be included. we do not intend to trade all this stuff for a 200.00 parts car that is barely a shell. 2 door preferred but if enough parts on 4 door, will consider that also. we want to be fair in this so please try to understand this. i have 10 pics to post and can get more if needed.
