mopar56
my son is rebuilding a 340 for his pick up, he got the block punched .040 over and had the machine shop supply the bearings, pistons, rings, etc, the rods were machined and came back assembled with rod caps, the bloody things are on TIGHT!, we have tried to separate them, the first one was tough but we were able to get it apart, gently, then install and plastigauge it, but again tough to get apart once in the cyl, any way on to the second one, we can not separate it we tried using the block of wood trick, a dead blow, etc, I know you should be able to separate it with your fingers but it aint happening, we seen a couple tools made for the job, one was a pretty elaborate hydraulic version, we heard about using a plastic cone in the center then tapping the rod with a dead blow, any one know any tricks?, help!, thanks.
