johnparts
Slammed 1
Guys I finally got through to Diablosport and got my CMR tuning software reactivated with my new laptop I had locked my last ip address from them. I can handle most MILD changes like injector scaling ( using 5.7 with 6.1 injectors I can adjust the fuel trims) I can turn off tcm's I can disable rear O2's I can adjust idle speed, I can add a 2 bar if you want to run boost, I can do some mild tuning with datalog's, and I can tell your pcm if you have a manual trans. PM me if you need something done and I will do what I can.
Oh I should tell you guys I attended EFI 101 paid for by mustang dyno's and have a certificate but I haven't had a ton of experience in full dyno tunes at WOT just a lot of part throttle drivability stuff.
