Need Help and Info........
eds70dart
Chatham Ontario Canada
I have a 70 Dart Swinger, 340-4 speed car. The fronts are disc and rears are drums. The problem is I need a new set of rear drums and don't have the originals to get any measurements off of them to replace them on the back end. Any Dart owners out there that have purchased any new ones. Also can you tell me where I can get them, and what size to get. I do live in Canada, so I got to watch how expensive I can go. I want to get as close to the originals as possible. Need some help here guys...
I have had good luck with NAPA. They are probably 11" or 10" I'm pretty sure 11" on the rear and 10" on the front if you didn't have discs.
I,ve built 2 8 3/4 rears,the last one I built with parts from Carquest.If you can measure your brake shoes then go and order.If they don,t have in stock,they,ll get them.If not,try NAPA.
