Need help az guys
03ramit1
Glendale Az
I am in need of a shop that can roll a 2inch Aluminum tube into 3/4 of a circle. You guys know a shop that can handle it? The circle needs to be close to 4th in diameter
There's a guy on ebay that has some aluminum tubing that has some really tight bends. Perhaps he can help. Also, a couple of years ago I had to turn some 2" aluminum into a very tight turn on a turbo setup. I got some 2" 90 degree bend on ebay and cut some wedges into it and had it welded shut. Didn't look bad after it I sanded off the excess weld. Perhaps that would work for you. It cost me $50. Bill
