6dart9
- Joined
- Jan 8, 2008
- Messages
- 762
- Reaction score
- 14
Ok i went with the Summit Direct Fit radiator made by northern
I have 3.5" from Radiator to the water pump pulley
The electric fan that I have is to thick to fit in the space.
So now should I go with a mechanical no clutch and shroud?
I don't think the clutch will fit with the fan
What fan shroud should I go with I saw FBO has one and then there are some that summit has as well that have a 16" fan diameter. Most fans I am looking at or have looked at are 18" in diameter. anyone know the diameter of the viscious fan is?
What about those shrouds that just go over the top they have?
Do i even need a shroud?.... I live in California i am sure i wil be in traffic once in a while
Any help would be appreciated i figured i could just use my elec fan i had but that will not work so now im back trying to figure out fan shroud combo
the endine is 340 904 tranny
