need help wiper on 65 cuda
rick travis
Member
plymouth,pa
is there a way I can temp get my veriable speed wipier motor wired to an on off switch (aftermarket of course) , cant afford that expensive switch right now any help or diagram would be greatly appreciated, ty in advance
The wiper motor is the same for both single and variable speed with the main differences being in the actual switch and a separate 2 wire harness added from the switch to the motor and the actual connector at the switch. If all you need is just the switch I will take a look later today and see if I have an extra one.
Both switches shown,
But it is vague.
One circuit is motor, other circuit is park switch.
Switch terminals are marked, p im assuming is park.
I have one from a 66 belvedere that's why I wanted a pic of it. Kind of long and has the pushbutton in the middle for fluid.
That what you need? I would send it just for the ride, it works and is in good shape.
Same basic switch but the shaft is way too long for a 65!
Here’s what a variable speed switch for an early A Body looks like - later years might be different!
