need help wiper on 65 cuda
rick travis
plymouth,pa
is there a way I can temp get my veriable speed wipier motor wired to an on off switch (aftermarket of course) , cant afford that expensive switch right now any help or diagram would be greatly appreciated, ty in advance
Got a pic of the switch? Might just make your day!
this is accurate but slightly vauge on which term to send single power too, I'm more of a bodyman,lol
The wiper motor is the same for both single and variable speed with the main differences being in the actual switch and a separate 2 wire harness added from the switch to the motor and the actual connector at the switch. If all you need is just the switch I will take a look later today and see if I have an extra one.
Both switches shown,
But it is vague.
One circuit is motor, other circuit is park switch.
Switch terminals are marked, p im assuming is park.
I have one from a 66 belvedere that's why I wanted a pic of it. Kind of long and has the pushbutton in the middle for fluid.
That what you need? I would send it just for the ride, it works and is in good shape.
Here’s what a variable speed switch for an early A Body looks like - later years might be different!
