DEMONIZED340
Demonized
Hello all!
Just a lil history first. When i bought my 1972 Dodge demon i noticed the d/s door glass was hitting / rubbing against the chrome on the rear pop out window when i would close the door. I could move the glass by hand horizontally back and forth quite a bit. So, i removed the door panel and seen 1 of the 4 plastic bushings / washer nuts that go thru the glass w/ the screw was missing. So, i replaced all of them, tightened up all 4 screws and the horizontal movement was gone. Now here are my issues:
The front of the door glass ( above mirror ) is NOT touching the weatherstripping which is allowing water to fill the floor boards when it rains. I bought brand new weatherstripping and have the same issue. Looking at the passenger side door glass i noticed that the glass is 3/16" forward of the cat whiskers on the door at the rear when rolled up. The d/s door glass is in line with the cat whiskers at the rear. This tells me that the d/s door glass needs to be pushed forward towards the mirror 3/16". The plastic bushings / nuts that goes through the glass w/ screws does not allow for any adjustment.
Is it possible that some part was replaced at one time is wrong? Is there a way to adjust horizontal movement of the door glass? ( i know of the vertical adjustment ) Is there a way to adjust the top of the glass to tilt inward to touch the weatherstripping? Also, i can grab the glass and pull up and get excessive non resistance movement, though the window rolls up and down w/ no problems, no skipping, stripped gears etc. FYI: I have already tried adjusting vertically thinking the window was not going up high enough, and the glass needs to move forward 3/16" to be in the correct placement compared to pass. door glass. Any help would be much appreciated!
