1970b5swinger
1970B5SWINGER
converted my 1970 318 dart air conditioning to 134 A put in a can to see if compressor kicks on, it did so bled the system put on a new dryer and a new accumilator valve put new o-rings were needed put the vaccum pump on for 2 hrs, began my install of new freon again after 1/2 can compressor kicked on this was done with car running and ac max setting on and temp control on cold after 4 cans it still doesnt blow cold air. I am not loosing freon, could the slide from hot to cold air be the problem or ??????????? your input will give me something else to look for
