I have a 440 bored .30 with a 509/292 purple cam. the heads I have on it are 4008452 casting. On the one side I can smell anti -freeze upon start up out the exhaust port. After it warms up the smell is gone. Does not leak water or use water. I think maybe the shop who did the head work maybe drilled one of the broken exhaust studs into the water ports.
I have an opportunity to get a set of heads with a 3462346 casting number and I need to know if those are a better set of heads or will it hurt me. Does anybody know the difference in these. Everything I come up with says they are about the same. thanks
