dartsport76
can't get right
I have a pertronics brand Flame Thrower coil, I have the + side wired to the Pertronics brand distributor and to a 12 volt sorce as directed in the instructions, the negative has a wire to the tach and to the black wire of the distributor. I have no spark going to the plugs but do have power to the coil, actually both side of the coil the neg and the pos are showing over 12 volts each. does this mean I have a bad coil or did I just have the world biggest snaffu. Any help would be great.
Thanks
Brian
Thanks
Brian
