Need help with innerfender fitment issues
440dart123
Columbia Falls Montanya
I didnt get much action over in the early a section so i thought i would post over here as you bigblock guys have probley delt with this situation alot more.
I have a 65 dart that iam looking for some help with that iam turboing, i was going to use magnum manifolds and they will fit with very little effort but i found a set of headers on a truck in my salvage yard off a magnum everything is in the same location but the tubes stick out alot further and wont fit because it hits right where the uppershock mount is.
Do any of you have any ideas on what i could do to make these fit i was thinking of cutting out the inner fenders but it sounds like i would need to a cage can i get away with just tieing the front to the firewall any ideas ???? Iam not opposed to putting in a cage just wanting to get this going and tuned with as very little cosmetic work as possible then put a full cage in later.
Maybe i could shorten the shock mount and run a shorter shock? any ideas????
Can you cut the flange off the headers and shorten the tubes closer to the block?
