Need help with turn signals
1969GTS
I'm close to getting the Dart on the road but still have some electrical issues. I have all the lights working, the flashers working and just installed a new turn signal switch in the steering column. I still have no turn signals how ever the horn works and everything else seems to. I have a wiring diagram and don't seem to have any power to the turn signal switch. Any suggestions? I hate wiring!
Thanks
Just had the EXACT same problem myself!! I changed BOTH flasher units.. and problem solved.The 4 way was behind dash mounted and the turn signal one was close to glove box.. Did you do both??
Nope. I'll change the other one and hope for the best. I assume any auto parts store will have them.
Thanks a ton
Yup. now my front left just quit! Not the bulb and was working fine! It never ends sometimes. lol
