[WANTED] Need one lower ball joint bolt and nut
It would help if you give us some more iformation.
1. You need one for 9 inch drum brakes?
2. You need one for 10 inch drum brakes?
3.You need one for 65-72 disc brakes?
4. You need one for 73-76 disc and drum brakes?
My first thought. Right On!
Ah that is better. The only ones I have are on a pair of spindles I have. But that said, if I were you I would take another one with you to a pick a part yard. One on another A B or C body should be close enough to work.
