Need picture 64 to 66 Barracuda windshield washers
davescuda
Cheshire, CT
Need picture 64 to 66 Barracuda windshield washers sprayers, squirters or nozzles what ever they are called.lol
thanks in advance
thanks in advance
I don't have any pictures. They are mounted on upper cowl and go thru a hole in the cowl and the nozzle
is mounted between the cowl grates. If I remember there should be holes for the squirters and small punched
holes for the mounting screws.
thanks in advance
Dave,
Not sure if the cuda has them set up the same as the dart, but here is what they look like on my 64 dart...
66 Barracuda, same part left and right. Don’t know if the plastic splicer is reproduced. They were hard to find due to being brittle. A soft robber washer should be used as to fasten it
The splicers are reproduced picked up a couple last summer at Carlisle.
The fancy Tee is reproduced because Mustangs (67-70 I think), Broncos and Ford pickups use the same thing. Napa used to have them here in town if looked up as a Ford application.
