Need pictures of lower console auto linkage.
mattsmopars
Cookeville,TN
I have been working on my 72 duster removing the A/M shifter and installing the original console and shifter back in to the car. I believe that I have the correct pieces, but I would like to see if anyone can post some pictures of the correct stuff and some installed pictures?
I really need to see for sure the lower linkage rod and the correct gear selector that bolts onto the trans itself. Any help would be very much appreciated.
Thanks, Matt
Yes it does, but I also need to see the other end if possible plus the selector that bolts onto the transmission. I am trying to compare what I have to what is know to be original working stuff if possible. Please
Matt
904 or 727 trans? The gear selector levers are different
Here is the trans shift lever. 6pk provided pics of the rod.
Thank you for that picture that is what I thought it should be. It also tells me the one that's on my car is wrong.
Also if anyone can please post a picture of the rod end at the adjuster and where it mounts to the selector I would appreciate that as well.
That was I have as best of an idea as possible for what its supposed to all look like.
Thanks for all the help.
Matt
