need radiator 67 cuda 340
kurt
chicago
what a good radiator and were to get one for good price has any one use like 93 dakota radiator what will work check the bone yard but all bad
I usually check RockAuto.com
They have some pretty competitive pricing. Also, if you have a delta auto parts store close by, check with them. Their pricing is also competitive.
I bought mine from them. Does your car have the steel or alum water pump? The steel is 69-down & alum is 70-2 for 22" rad opening a bodies. I have a 67 Valiant with a 72 340 so I just ordered 1 for 70-2 duster v8 with a/c.
I have an original one that came out of a 67 Cuda 22 inch
273/auto car, but I'm certain it would at least need a new core
put in it. PM us if this may be of interest to you.
$220.00 led foot racing shipped.
You can find this model cheaper but i went with a long time running company so if i had a problem in the future with a warranty issue.
I just installed a American Eagle radiator ment for a 67 383 big block Barracuda.
It works great..................you just have to find hoses that will fit.
I used a regular smooth hose on top and used a flex hose on the bottom.
I am building a big block and when i spend money i try to keep going forward and only spend money on the big block build.
I had to change nothing on the engine.........steel water pump small block.
Drivers side lower ---- pass.side upper---22 inch Two row 1 inch tubes ------American Eagle---------
------Part # AE2375----------COOLS 600 HORSE------
The only modification i did was drill a hole for the lower mounting bolt on the Passenger side lower part of the radiator.
I am using a Mopar Performance fan on the 318 and even though it sits back a little from the radiator it still stays cool.
---------------180 degrees,with a 180 stat-----------:thumbup:
