[WANTED] Need radiator for my 360 engine
cudajim
cudajim
Grass Valley, Ca.
I now have a 360 engine with 904 trans (which replaces the 318) in my 67 Barracuda and am in need of a radiator since the lower hose is now on the passenger side. I'm open to suggestions, hoping I can get something rather inexpensive. If you're near Sacramento, Ca. I can pick it up.
new at auto zone for 70/72 v8 new 168.
Or you switch to the early style timing chain cover and water pump, you can use the original radiator. Just remark the timing marks on the vibration damper for the other set of marks.
I have one for sale in the Mechanical parts for sale from a 66 273 that should work. $75 + Shipping
no that will be wrong side bottom 71 they changed to the aluim water pump , and spout is on other side if you use the 340 wich I did make sure you get a double set of nipple fittings they cast them in in the 71 and up heater hoses are diff sizes in most watch out or you will blow your heater core 1 is 1/2 , 1 is 5/8 then you have to get the right bypass fittings and hose just a heads up ,and my mechanical water temp is to big for my m1 intake I either get a new guage , or get the drill and tap out the hole is same as hot light fitting and the air gap style isn't that deep where the water flows on it eddies might be diff just a heads up
