richmann80
Active Member
ok well i'm new here but i have a 70 duster with a 440 and a victor manifold problem i'm having is the motor runs great doesn't over heat no wierd noises but i'm getting what seems to be raw fuel into the radiator so much so that i dipped a papper towel in to it and it would lite on fire pretty easy after only about a 10 min warm up i have 906 heads mild port work i was thinking cracked head but it doesn't run like that or have water in the oil just wondering if anyone else had this problem using a victor manifold i was told some time they don't seal right and that could couse what i'm see i don't see how but if any one has seen this before if you could please inligthin me so i don't go ripping and tear at things that don't need to come apart
thanks
rich
thanks
rich
