a34
The Etowah Flash
Hey guys,
I picked up some parts the other day and need some help on the applications.
The first is a 4spd tranny with c-97372 on the case and a aluminum tag on the cover that has 11-4-66 stamped into it. The tail shaft has C-956647 cast into it.
I have another one that says c99129 and the tail c99126 and on the stamped pad says PP8332819 on the pad with 152 beside it and I guess a partial vin of 9B360756.
Lastly I have one that says the same as the one above, but the stamped pad says p8332617.
I also have a cast iron bellhousing that the numbers look to be a half inch in height and much wider than normal. Hard to see what they say, but the first couple of number seen to be 28. Never seen one with numbers so large cast into them. Anyone seen something like this?
I have a power steering pump with c-3643012-f cast in it. Is that all A-body's?
Thanks for any help guys !!
:wave:
:wave:
