Need some room sale.
sireland67
WV
Garage sale,
I have the following items up for sale.
I am located at 26301 WV all prices do not include the ride.
Small Block cam and lifters, I cannot identify the brand, hydraulic flat tappet, lobes measure out at 502" of lift, numbers on the cam are 1136, H7, D2, H7, O2, cam and lifters show very little wear $30.00
Fuel pump and regulator, pump is a rebuildable Carter for a big block mopar, still pumps good, regulator is a holley with a fuel pressure gauge, the gauge is missing the lens $30.00.
(SOLD) Holley carb is off a 1970 440 570 cfm list #4366 throttle plates are all tight, carb will need a kit, complete carb $35.00.
(SOLD) Intake is a small block eldebrock, sand blasted with new 180 degree thermostat, wipe the dust off and bolt on $75.00
(SOLD) Thermoquad is off a 77 400HP list #9077S throttle plates are all tight, carb will need a kit, complete carb $20.00.
Valve covers are off a 94 360 magnum, have been cleaned on the inside, but will need exterior clean up, I have misplaced the oil filler cap, $30.00
I will trade the big block fuel pump for a small block one it it is the carter rebuildable one.
The big block one works fine.
