Need someone to install Neon timing belt...
DonnieLawson
68 Barracuda
Middletown Ohio
My daughters 2002 Neon died at a traffic light the other day .
When We brought it home , I saw that the timing belt was stripped. Im guessing that it will need a valve job also. Dam interference engines.
Anyone in the Dayton , Middletown - Cincinnati Ohio area interested in doing some wrenching ? I could buy the parts and pay for the labor .
I just have a boat load of overtime to work and the daughter is in need of the Neon .
Thanks
Donnie
id try to just put a belt in it.. you said it died at a traffic light. Ive done probably 10 neons and only 1 bent the valves when belt broke on start up or at idle... i've saw the most damage done with 5 speeds at highway speed
Yep , It died at a light. She tried to re fire it then finally called Ole Dad.........
I had her hit the key with the plug off the timing belt cover and the cam pulley wasn't turning .
It is a Automatic.
I would sure like to a local guy with some Neon experience tackle it for us.
Thanks Donnie
