NEED STARTER HELP
74@scamp
Milwaukie oregon
I am in search of help with finding the correct starter. Vehicle is a 1974 plymouth scamp with a 1986 la360 matched with a 1972 a904 automatic.
I ordered a powermaster mini high torque adjustable starter from summit and it bolted up great, but the raised part around the starter gear hit the flex plate so I returned it and power master recommended one with a nose cone but when looking at the photos it also looks like it has a raised portion around the gear that will hit.
Has anybody else had an issue similar to this? Can somebody recommend part numbers or other companies i could contact to get more info
Any help is appreciated. Thank you
1993 dodge Dakota mini starter.
The very first upgrade to all mopars. Cranks fast, starts fast.
Get the one with this style cable connector.
