Need the factory battery cable lengths on 66 with 273 engine and A904
Two Time Signet
WA
Does anyone have the negative and positive battery cable lengths for a 66 273 automatic a body? I'm having one of our members make me a set. My positive cable appears factory but won't have access to it till next week and will need to disassemble to measure it and it will completely fall apart when I do so.
I believe the factory negative battery terminal to cylinder head (or intake bolt on some), single cable, is 19 inches.
Does anyone have the measurements on the positive battery terminal to starter and relay cable lengths?
1966 service manual shows two wires off positive terminal:
A1 6B gauge red color to starter motor solenoid.
A1A 10 gauge black color to starter relay switch.
I have an exact reproduction positive and negative cables for my 65 Dart. These were made by M & H per the actual blueprints. 66 measurements were likely the same
