JTG
- Joined
- Mar 19, 2010
- Messages
- 799
- Reaction score
- 46
Hello, my 68 Barracuda 340 starts up 100% perfectly fine, once off choke it will idle on its own at operating temperature then it will slowly die and stop running, upon restarting it turns over but will not run because it has no spark. This problem seems to be intermittent, car doesn't do it all the time.
This car has a new HEI setup installed with the Petronics flamethrower coil, the ignition wires (Taylor409), spark plugs (NGK), alternator (100amp), voltage regulator, battery (Optima) are all brand new. Any suggestions please inregards to what may be causing this problem will be much appreciated.
