jeffs67dart
Member
I have a 904 in my 67 dart and the previous owner installed a b&m floor shifter (it originally was column shifter) and I want the back up lights to work. I'm pretty new to mopars so I researched and found in 68 or 69 they changed the neutral safety switch on the trans to a neutral safety/back up light switch. my question is can I replace the single pin switch with the 3 pin switch, find the back up light wires in the column switch and run them to the 3 pin switch on the trans and the lights will work, or is the early torqueflites different internally? I can get the switch and correct plug for switch on ebay new.
