Myself working with threaded aluminum in The Oil & Gas world for over 35 years in Maintenance running all sizes of aluminum pipe (threaded conduit) has
always taught me to put some anti Seize on the threads .................IF YOU WANT TO POSSIBLY GET IT APART AGIN AT A LATER DATE!!!!!!
It is a horrible feeling to feel that galling happening as you are trying to get it threaded together.
So the real question here is to put never seize on a spark plug that is going to be threaded into a Aluminum cylinder head. YES, YES, YES I know what NGK states on their instructions that Never seize is NOT NEEDED...... because of some cadmium plating that they use in place of any type of lubricant.
But I suggest you see that part about one real bad feeling when anything aluminum starts Gaulding while being screwed together.
On the other hand in my technical call to NGK some Asian woman that works for NGK states never apply any anti seize being put on their spark plugs period due to miss fouling causing plug ground insulation, miss fires amongst other problems. I noted her comments
I will never and I mean never install any spark plug in any hole without it being on there. So tell me what you think!!!!!!!!
What do you do when it comes to your aluminum heads. Please advise Texas Red
