rampage340
$2800,00OBO
New 350 chevy 2bolt block STD bore with ARP bolts, New chevy crank, New chevy rods with ARP bolts, New hypereutectic STD flat top piston, New speed pro moly rings, New clevite rod main cam bearings, Windage tray, Melling HV oil pump pickup, HD driveshaft, 6QT chevy oil pan, Cloyes double roller timing chain with lock plate, New Crane 244' 518/536 solid cam,lifters,springs, retainers, locks.
New World products sportsman S/R torquer heads with Manley 202 160 s/s valves 7/16 ARP screw in studs with guide plates, Manley moly 3/8 push rods, Used crane gold race 1.5 roller rocker with stud girdle, Used moroso tall chrome valve covers, Victor JR intake has been port matched, BG750 carb, Accel BEI distributor, SFI Damper, SFI Flywheel, Mini starter, Fuel pump block off , Holley blue pump. All new FelPro Gaskets with reusable, Oil pan and Rocker cover gaskets. Just add oil lash valves and prime and start. can deliver up to 50 miles with deposit
