New 360 what time ?????
Headers.
Certainly the camshaft is the problem but should I be going backwards this far?
Anything is possible. Did you degree the cam when you put it in? If you don't want to pull it outright, check the lash, check the lifters, etc.
Since it's a new shortblock, I'd do a leakdown before anything else. Make sure you're not having ring seal problems (or you don't have a bent valve or something).
Steve
this may be the reason for lost et's , if the cam has 268 duration at .50 the advertised duration is about 306/308, if you look up the power range it should be around 4000 to 7200, to get a good low end you need at least a 5000 stall converter and around 456 to 488 gears.you are running to much cam for your setup. good luck Gary
