[SOLD] New 727 8" race converter from Dynamic Converters
physixx
Edison, NJ
I have for sale a new 8” 727 race converter from Dynamic Converters in Newark, DE. This converter has P/N 11708 SP and was installed in a trans but never run or the car started. We put fluid in it before mating to the trans as is SOP so there is a little fluid in it. It was in a project car that was never finished as we went in a different direction. There are no starter marks on the teeth of the ring gear so it’s evident that this converter has never been used. It was going to go behind a 440 engine so the flash speed is 5000 rpm or more depending on your engine combination. From the numbers stamped on it, it has a turbine blade and is built for a larger engine. This converter is NOT designed for use with a trans brake. I would like to get $750 for it plus the shipping.
Ken
Edison, NJ
