Ram Clutches has stepped up to the plate for the early A body guys/gals with the addition of some serious clutch options for the 122 tooth 9.5" flywheel commonly used with the 273 and slant 6 engines. Before now, running higher HP small blocks meant the necessity to upgrade to the later model 10.5" clutch/fw/bellhousing.
Single disc clutch & flywheel options capable of handling up to 500 HP. Twin disc clutch options capable of handling 600-750 HP.
