[SOLD] New B/RB MP Purple Cam Kit P4349268AE
steven775
Member
Jacksonville, NC
$150 Shipped
Located in Jacksonville, NC 28543
Mopar Performance Purple Camshaft Kits P4349268AE
comes with cam/lifters/lube
Applications 383, 400, 426, 440
New
Cam Style: Mechanical flat tappet
Basic Operating RPM Range: 4,000-7,000
Intake Duration at 050 inch Lift: 275
Exhaust Duration at 050 inch Lift: 275
Duration at 050 inch Lift: 275 int./275 exh.
Advertised Intake Duration: 324
Advertised Exhaust Duration: 324
Advertised Duration: 324 int./324 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.620 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.620 in.
Valve Lift with Factory Rocker Arm Ratio: 0.620 int./0.620 exh.
Lobe Separation (degrees): 106
Camshaft Gear Attachment: 3-bolt
