[SOLD] NEW Comp Cams 4937 Cam Degree Kit
cuda_Jeff
Active Member
Adairsville GA
New, never used. I bought this to build an engine but ended up buying a crate motor.
I'm in North Georgia, but I can ship anywhere in the world with UPS.
Price is $165+ shipping.
Info copied from Summit
Brand:
COMP Cams
Manufacturer's Part Number:
4937
Part Type:
Camshaft Degree Kits
Product Line:
COMP Cams Camshaft Degree Kits
Summit Racing Part Number:
CCA-4937
UPC:
036584720768
Degree Wheel Included:
Yes
Degree Wheel Diameter (in.):
9.000 in.
Degree Wheel Material:
Steel
Degree Wheel Finish:
White
Number Color:
Black
Cam Checking Fixture Included:
Yes
Dial Indicator Included:
Yes
Piston Stop Included:
Yes
User Manual Included:
Yes
Valve Spring Checking Springs Included:
No
Wire Degree Pointer Included:
Yes
Video Included:
No
Case Included:
Yes
Case Material:
Foam/Plastic
Case Finish:
Black
Quantity:
Sold as a kit.
Notes:
Designed for Mopar (will not fit late model Hemi, see Comp Cams 4944) and Oldsmobile V8 engines. This kit contains everything needed for camshaft degreeing with the heads off the engine.
COMP Cams camshaft degree kits dial-in your cam accurately! Degreeing your cam properly means better performance and these degree kits offer precision results. These kits have everything you need to work with the cylinder heads off including an easy-to-read and clean COMP Cams Sportsman 9 in. degree wheel. You can check cam lift, base circle runout, piston-to-valve clearance, top dead center, valve lift, valvetrain flex, and rocker arm ratio. Position your camshaft for performance with COMP Cams camshaft degree kits.
