[SOLD] Small Block LA COMP Cams Nostalgia Plus 484/484 Cam and Lifter Kits CL20-671-4
FourSpeedDemon
Nor Cal
New in box, the box has white spray paint overspray in it but the cam/lifters weren’t affected.
$300 plus shipping from Woodland CA 95695
Cam Style:
Hydraulic flat tappet
Basic Operating RPM Range:
2,500-6,400
Camshaft Use:
Street/Strip
Intake Duration at 050 inch Lift:
239
Exhaust Duration at 050 inch Lift:
246
239 int./246 exh.
Advertised Intake Duration:
284
Advertised Exhaust Duration:
291
Advertised Duration:
284 int./291 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.484 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.484 in.
0.484 int./0.484 exh.
Lobe Separation (degrees):
108
COMP Cams CL20-671-4 COMP Cams Nostalgia Plus Cam and Lifter Kits | Summit Racing
