[SOLD] New! Comp Cams Ultra Pro Magnum Shaft Mount Rockers LA Small Block Mopar P/N1622-16
Propwash
FBBO Cat
The Muppet Show
***SOLD***Going a little different route with my roller rockers, so I'm selling these. This kit is new (still in the box) and comes with the rockers, shafts, spacers. There is no hold downs or shims with this kit from comp. Very good quality!
Spec's from Comp:
Brand COMP Cams
Maximum Spring Diameter (in) 1.625 in.
Notes Requires a ball/ball end pushrod.
Part Type Rocker Arms
Product Line COMP Cams Pro Magnum Shaft Mount Roller Rocker Arms
Quantity Sold as a set of 16.
Rocker Arm Body Style Standard
Rocker Arm Finish Natural
Rocker Arm Material Chromemoly steel
Rocker Arm Mounting Style Shaft
Rocker Arm Ratio 1.5
Rocker Arm Style Full roller
Self-Aligning No
Shaft Diameter (in) 0.872 in.
Shims Included No
I'm on the road for a couple more days, so I don't have an actual pic as of yet. Here's a pic from comp cams:
I paid $560 from Summit for these two weeks ago. I'll let them go for $460 and I'll toss in the shipping (for lower forty-eight).
Thanks for the ad FABO! My location is Greenville, WI if you are local and want to take a look at them.
