new Damper benificial?
V8-valiant
Central Oregon
hello all, i got alot of help from you all on my cam choice and was wonerding if there are any benifits from getting a new harmonic damper when i do my cam chance, currently im running my stock damper doesnt seem to have anything wrong but will i benifit or would it be a waist of money?
Item# newitem101747709
Product Description
PRO/SPORT Harmonic Dampers feature :
• Meets SFI Spec. #18.1
• Spin tested to 12,500 rpm
• Fully machined from high quality carbon steel
• Retained outer inertia ring
• 60o of permanently engraved timing marks
• Pressure bonded elastomer • Accurately balanced
• Removable counterweights on externally balanced models
The Economical SFI Approved Crankshaft Harmonic Damper!
The PRO/SPORT Damper
Specialist Harmonic Damper manufacturer, PRO/RACE Performance Products, is introducing the new PRO/SPORT line of SFI dampers! Harmonic Dampers play a vital role to ensure longevity of engines and crankshafts, and are arguably the most important external component of an engine. Harmonic Dampers protect against harmful engine harmonic vibrations that can lead to valvetrain damage, rapid bearing and timing chain wear or ultimately crankshaft breakage. Why trust dampers from any other manufacturer, when PRO/SPORT Harmonic Dampers are engineered with more than 20 years of SFI damper manufacturing experience.
The PRO/SPORT range of Harmonic Dampers provides race quality performance dampers at near replacement part prices and are available for most popular V8 engines.
Designed as a direct replacement of our OE damper, the PRO/SPORT Harmonic Damper has many features which exceed OE requirements! Manufactured to the quality standards you have come to expect from a specialist Damper manufacturer, the new PRO/SPORT SFI Harmonic Dampers are produced from quality carbon steel, with mechanical properties exceeding the stringent SFI Spec. #18.1 requirements! Spin tested to 12,500 rpm for one hour to comply with SFI Spec. #18.1, so when your racing needs require SFI certification, the PRO/SPORT Harmonic Damper is ready for the track.
Machined to exacting tolerances and assembled using pressure bonded elastomer technology of tried and proven design for optimum damping performance! The outer inertia ring is retained by a robust retention plate secured by 6 high tensile bolts to ensure maximum safety of the product. Extremely accurate and easy to read permanently engraved timing marks make engine timing easy, and 90o marks simplify valve timing operations.
Unlike many other SFI dampers which are not bonded, the PRO/SPORT range feature a bonded elastomer! The elastomer is injected at high temperature and under extreme pressure and is cured against a specially prepared and chemically treated surface on the inside of the ring and outside of the hub. The result is a bond similar to that of a motor mount… which makes it almost impossible to separate the damper hub from ring! In fact during the manufacturing process EACH AND EVERY PRO/SPORT damper is subjected to elastomer bond test of 3000lbs separation force. If there is any sign of bond degradation then the damper is scrapped.
All externally balanced Dampers feature accurately machined counterweights which bolt into the hub of the PRO/SPORT Damper. This not only provides extremely accurate engine balance due to the precision of the counterweight mass but also allows for easy conversion to neutral balance by unbolting the counterweight, should that ever be required.
PRO/SPORT dampers come attractively packaged, are highly polished and finished in a durable baked enamel finish to preserve the damper that looks as good as it performs!
Chrysler V8 - 318-360
TYPE: External
WEIGHT: 11.93
$184.99
PRB34278
