Suggestions anyone??
Got thru only 10 minutes of engine break in last week and thought the thermostat was bad. Coolant spewed everywhere out the blowout. This weekend cleaned everything up, hooked up temp gauge, refilled coolant, checked everything for leaks and fired it up without a thermostat and plenty of water ready. Had a house fan set up blowing on high right at the radiator. Five minutes into break-in had to shut it down again as everything overheated and coolant was spewing.
Everything...and I do mean everything ($6500 +) is new. New radiator, new water pump, new engine, new hoses, new ignition/distributor. New, new, new. What the heck is happening here?
It is a 340 bored 30 over. Radiator is new and is stock 22'' Mopar. Water pump is Mopar Perf.
What to try next? Timing? Head gasket issue? Bad water pump? Not good enough radiator? Help please. I'm at a loss.
I am running it with open exhaust for just the break-in because to put the TTI's on it will void their warranty. Stock exhaust manifolds are on it but the exhaust system has been cut off in preparation for the new stuff. Could this be part of the problem?
