[SOLD] New Forged 340 based Stroker Rotating Assembly Kit
Rocket
CT
I have a new SCAT forged rotating assembly for 340 Mopar engines. All parts are new high-quality parts. I have two choices of pistons – Diamond 4.060” bore or Mahle 4.070” bore. Final cubic inches will be 414” or 416” respectively.
The assembly includes the following parts.
  • SCAT forged 4.000” crankshaft part # 4-340-4000-6123
  • SCAT forged H-beam connecting rods with APR 2000 bolts part # 2-360-6123-2124A
  • Your choice of pistons and rings - either:
- Diamond Forged flattop 4.060” bore pistons (0.020” oversize) part # 51028 with Trend wrist pins part # TPD-G9842750155, Diamond wrist pin locks and Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065 or
- Mahle Forged flattop piston kit # SBM460070F05 which includes 4.070" bore pistons (0.030" oversize), Mahle file fit moly rings, Mahle wrist pins and pin locks
  • Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH
  • Clevite P-Series full groove main bearings part # MS-1344P
This rotating assembly will need balancing.
Price for this complete kit with the 4.060” Diamond piston option is $2,750 plus shipping cost.
Price for this complete kit with the 4.070” Mahle piston option is $2,700 plus shipping cost.
I can also meet in or around CT.
PM with any questions you have.
Unfortunately I only have this one 340 based stroker kit available. It is a kit I put together to build an engine but my plans have changed.
Thanks for the inquiry.
