New fuel line....where to run it
elevensies
Uk
I'm just replacing my 3/8 fuel line with 1/2"
Iv used aeroquip and externally it's 1" and massive, and iv had a bit of a head scratcher as to where to run it up through the engine bay
Any pics of people's running up to the fuel reg and carb please
And how you've routed it from underneath :)
Really appreciate
I've seen quite a few people go through the inner fender with a bulkhead fitting.
For some reason I don't have a pic of the entire fuel line routing but mine runs along my frame and subframe connectors up to the regulator in the engine bay on the inner fender.
Great, looking car :)
I'm really looking for where you pass through the front frame up into the engine bay, as I'd like to pass through as cleanly as possible
The lines run under the crossmember, not through any frame/bulkhead connector or anything.
cool thanks :)
any reason for not running through the frame? i assume just in case it was rubbing?
