I was very close to Monster Mopar this last year, just couldn't quite make it. More info on the car. It's a 440 with built bottom end. 10.6to1 compression. Ported edelbrock RPM heads, Mopar solid cam 28X something duration, .539 lift at the valve, comp cam stainless rockers, M1 single plane, Holley HP750 carb. 727, 2600 stall, cheetah reverse pattern valve body. 8 3/4" w/ 4.56 rear gear on a locker with Moser axle shafts. 3" spring move and mini tub. SS springs with soon to be added slide-a-links. I have some body work that needs to happen. The drivers side pillar behind door is cracked and wavy from flex, a small dent above passenger front fender, paint is not the best, about a 6 or 7 I would say. Little things like that.
