TheCraigMachine
Hey guys. Im in the process of trying to build up another 318, and I have a few options, each varying in cost. One shortblock I have has been rebuilt sometime in the past with a .030 overbore and fitted with rebuilder pistons that sit a whopping .105 in the hole! The bores show very, very little wear. Using the ring gap method of checking bore taper, i only get a difference of .002 from the top to the bottom. Most of the crosshatch is still visible in the bores.
Id like to be able to fit this block with some new .030 over KB399 pistons and run the stock 318 heads with bigger valves and porting. My question is, can I run hypers in a used bore? Ive always heard that hypers had to be "fitted" to the bore to keep from breaking the skirts, but Im not so sure about that. If thats the case, then why do ALL of the GM LSx motors clatter from piston slap? Those engines run hyper pistons and loose PTB clearance, and run for hundreds of thousands of miles without issue! The KB website states that their hyperutectic pistons can be ran with as much as .005 of piston to wall clearance without fear of breakage, so I think i may be able to pull it off.
Does anyone here have any experience in slapping some hypers in a used bore?
