New modified Rpm Intake for Mullen Cyl Heads !
SS Lancer
North Carolina
Well RPM intake is done
Professionally ported & center divider cut out - inboard (4) bolt holes welded up and re-drilled for W2 pattern !
Sorry forgot photos !
i had that done to my air gap , problem was the intake makes power to 5500 -5600 then drops like a rock . if you got good heads go victor or super victor , i'll give exact numbers over the winter on the difference between intakes , as my engine is pulled ready for some upgrades and before and after dyno runs
My opinion is that magazines get a commission for every dual plane intake that is sold.
Running Mullen
Direct Connection heads
Class specific
I saw it on Facebook. Sure looks good......but no surprises there!
I didn't use this because of an article , I did because of class rules etc .
I can afford any intake made but when it comes to dual planes the [ RPM ] is as good as any other offerings including the Legendary LD340 offering .
Im also allowed up to 1" carb spacer so I guess a Wilson unit will be tried .
Super Stock class [ Southeast Gassers ] dual plane only allowed !
Believe me I wish we allowed a single plane unit also .
good luck you should do well if that is the only type intake allowed
What's with the oval gaskets against the rectangle ports? When I first saw his FB post, I almost thought he was going to port them oval.
Well yeah, I know that. Was he comparing the size or what?
I had a few sets of those W2 gaskets luckily I saved a set and used for template after Reg LA holes were welded up .
